Well, I thought that I had a stuck Z-axis as a result of all the dried up oil that is all over the little Kitamura MyCenter Zero that I've been working on. However, I now suspect that there is actually some sort of locking solenoid in the Z-axis servo motor that is keeping it from moving. It is currently up against the second step of a limit switch. However, I used the over-travel function (that allows you to jog the axis off the switch in either .001 or .0001 increments) in an effort to get it moving. I can hear the servo motor trying to turn the ball screw, but the control throws an error and cuts the power.
In exploring the issue, I tried turning the ball screw by hand. Judging by feel, a friend and I came to the conclusion that there was some sort of mechanical stop that was keeping it from turning. Upon inspecting the servo motor, we saw a little part that looked like it may've been a solenoid that locks the motor. We removed the plug and found that it has about 112V DC running to it when the control is on. There are two wires in the circuit, and the "solenoid" side had around 297 ohms of resistance (putting it at around 375mA). It seemed like those numbers would be about right for a small solenoid.
Anyway, we are now trying to find some more information about this. We'd like to avoid having to tear apart the entire top half of the machine, but we're not really sure if there is a better way to proceed from here. Does anyone have any experience with something like this? The servo is a 5S/3000 (red octagon cap). I sniffed around fleaBay and only found one with matching numbers. It was listed for over a grand, so I'm hoping I can just work with the one I've got. Does anyone have any pointers? If so, please let me know. I have spent the last two years trying to get a working CNC machine in my shop (currently 0 for 2). Please help!
