tonymor
- Feb 9, 2017
- Chambersburg PA USA
I'm pretty sure I remember seeing a video a few years ago where someone had set up a robot to put a really long drill/boring in and out of a horizontal lathe.
I've done some looking now and I can't find anything even mentioning using a robot to do something similar.
We are making some long rods for hydraulic cylinders that require 40mm holes drilled up to 500mm deep.
The problem is the long drill needs to be put in and removed mid cycle so that it does not crash into the back panels/chuck when doing the rest of the machining.
We will be installing a robot fed lathe to do this work. Right now the idea is to have two lathes, with one dedicated for drilling.
Does anyone have suggestions for automating the process of putting the long drill in and out?
We don't need some amazing contraption that can change all of the tools on the lathe, just this one long drill...
