dalmatiangirl61
- Jan 31, 2011
- BFE Nevada/San Marcos Tx
Just to verify: Valve Lash == Valve Clearance?
I ran the leak down test without the camshaft installed so there should be nothing applying pressure to the valves.
Edit: I didn't actually answer your question, this WRX has the shimless buckets to adjust valve lash.
Yes, valve lash = valve clearance, same thing. Do leak test with cam out, install cam, repeat leak test, if the valves leak with cam installed, you found the problem.
Slowmotion or Turbowerks, explain shimless buckets, how are they adjusted?
