Are you using Glyptal 1201 from quart containers, or any of the sprays ? And are you brushing it on ? I saw some of your other machines, looks like you are using it on table tee slots and such, is that right ?
Side question too, I remember you wrote somewhere about your paint prep and finishes. You mentioned about using a heavy primer that acts like filler. Last week a fella with user name Lucaselef mentioned something similar in the South Bend section. I was wondering if it was the same stuff you used. His main comment here:
My 1959 Heavy 10 Toolroom Lathe
It had been on my mind how thicker stuff managed to spray through a gun, and he mentioned and linked a gun with a larger nozzle here:
I do use Glyptal 1201 in both quart and spray. I prefer the quart as it is a little thicker. I usually just brush it on the inside of a gear box then I always make sure to “bake” it. I do this by wrapping it in a welding blanket and dropping a 100-watt light bulb inside, leaving it over night or so. This speeds up the curing process. If you do use it in a gear box, I recommend waiting until it is hard enough that you can’t stick a fingernail in it before you add oil. Also, you must make sure that whatever you apply it to is completely degreased. I use it wherever I want a really tough finish or to seal up a casting. It sheds oil and dirt easily. The only case I know of where it failed was many years ago, I had a friend who used it in an engine. He either didn’t get it clean enough or let it dry long enough because it peeled off causing a lot of problems. But I’ve never had a problem with it.
Two other things about Glyptal…I never mask anything off in a gear box because I want to see where this stuff goes. If you get any of this on a surface such as a bearing bore, you want to be able to wipe it off with lacquer thinner and a cloth. Once it is baked on, it can be very tough to remove. The other is if you paint t-slots with it, be sure to paint only the bottom so there won’t be any clearance problems with t-nuts.
Below I’ve included a few pictures of where I’ve used it.
As for the high build primer, it is a product I use. I also sometimes use Evercoat high build primer in a can for small parts. The only thing I would say about using a high build primer is that you can use multiple coats and it will conceal minor blemishes. However, I try to guard against getting it too think as it is pretty soft, and I believe it leaves a part a little more vulnerable to chipping. It is really not a substitute for a filler, but rather a finish product.
I plan to conclude my restoration thread with a little bit on how I paint my machines.
