Pratt & Whitney 16x36 lathe value
cariboumatt
Mar 10, 2023
North Idaho
Good morning folks. I have an old B model 16x36 lathe, serial 595. It works really good as far I can tell but I'm no machinist. I've turned some very basic things on it just playing with it. The problem is it has a wobble to it when it spins. Is this a simple fix? We've also considered selling it but I don't know the first thing about lathes so I'm lost on the value of it. Anybody have any guidance on these issues? Thanks!
M.B. Naegle
Feb 7, 2011
Conroe, TX USA
Wobble? We need more information. Could be bad chuck jaws, bad chuck, or spindle issues.
I'd base 90% of it's value on completeness, bed wear, how many lathes are for sale near you, spindle top speed, and any known mechanical issues. Could be a $5000 lathe in the right machine desert, or could be scrap metal (unlikely). Location is a big factor. Your profile says Idaho, and I assume there's not a lot up there unless you go west into Washington?
Vecair
Feb 19, 2017
Prescott
You have a plain bearing model B denoted by the oilers on the headstock. No way 5K anywhere, more like 1 to 2K in that condition. I have several old lathes and in Arizona, never paid more than 2K. Better to figure out the wobble as it might be the plain headstock bearings which will have a major effect on value.
johnoder
Jul 16, 2004
Houston, TX USA
kitno455
Jul 9, 2010
Virginia, USA
Seems like the cross-feed really protrudes from the front of the machine. Is that part of a quick-withdraw mechanism, or something else?
Man, that thing is beautiful. I'd never sell it :)
Clive603
Aug 2, 2008
Sussex, England
The big P&W lathes have a double set of cross-slide ways. Top set is the normal cross-slide driven by the feed screw. Underneath set used for taper turning, it has a hole at the back to connect it to the taper turning attachment shoe. For normal turning the under-slide is locked to the saddle at whatever position is convenient. Usually placed where the upper slide and compound toolpost are in a position looking so similar to an ordinary lathe that folk not in the know don't realise the under-slide is there. That one has been pulled out way further than normal.
There is quick withdraw mechanism with, if I recall correctly, 1/2" or so of movement. The stops and lock bolt are in the lump immediately behind the cross-slide dial.
Clive
