I have a 5-40 UNC 2A threads that needs to be plated .0002-.0004 thick electroless nickel.
I am looking for some pre plated ring gages to use on this job. I am having no luck. I would have thought their would be something readily available.
I never plate over threads. In the rare instances we have done it in the past, it was mostly just trial and error as far as pitch diameter goes. We thought we left enough room on a zinc job but the threads came back too tight.
I know how to do the math to figure out where it should be prior to plating. I just thought there would be readily available pre plated ring gages.
Is using a UNC-3A gage ok for this? I feel like it would still be too loose. I am wondering if I am missing something as this should be pretty straight forward. Its not like I am the first person to do this.
Any advice is appreciated. At this point I am looking at using the correct gage and making sure the go gage is loose as can be without the no go gage going on. That should give me the tolerance needed for plating. I just feel there is an easier way.
Thanks in advance.
-Dan
Thanks in advance.
-Dan
