Preparation to set semi trailer on ground?
Garwood
Oct 10, 2009
Oregon
I just purchased a 48' refer trailer to use for storage. The axles have already been removed. The underside is completely flat, everything has been cut away sans the 5th wheel pin. It is aluminum exterior, steel crossmembers under the floor, aluminum plank floor, stainless steel walls and polyiso foam in the walls and floor and roof. There's nothing really to rot except for the wood roll up door.
Tomorrow, a friend with a crane is going to move this trailer for me.
If I set the floor beams flat on gravel with no air gap underneath will I have moisture problems? Critter problems? This is a wet climate in the NW.
This is about the same scenario as dropping a shipping container. Just no wood floor.
Scottl
Nov 3, 2013
Eastern Massachusetts, USA
Basically make sure the gravel under the container is flat and then grade the rest to slope away slightly so water runs away from the trailer. Also might not hurt to put double or triple strips of felt paper(stagger the end gaps) under the beams.
henrya
Jun 25, 2008
TN
I would put it on something slightly elevated above the ground. New crossties, ground contact rated timbers, solid concrete beams might all work. I am pretty sure that I could fight the occasional critter better than a sealed up rust and rot box it’ll never dry
Garwood
Oct 10, 2009
Oregon
I just went and took another good look at the bottom and it's not flat- The middle 15' has taller crossmembers so it won't sit flat on the ground regardless.
You guys have talked me out of setting it flat on the ground. I thought that would be nice for getting in and out of it, but it will probably create other problems.
At this point I'm thinking I will set it on four 6'x2'x2' concrete eco blocks. I shouldn't have more than 40K total weight trailer and contents which will keep ground pressure around 800 PSF with four blocks. I'll set the blocks so they are a foot above the gravel which will put the back tail light section even with the gravel. Then I can use that space under the trailer to store a bunch of steel siding that I was trying to figure out how to store inside the trailer.
Thanks for the guidance!
michiganbuck
Jun 28, 2012
Mt Clemens, Michigan 48035
Guess I would examine the grade to be sure an odd flood would not get the floor wet...and perhaps the gravel to add 2" height.
But the underside will be subject to darkness and still air so likely to mold.
Garwood
Oct 10, 2009
Oregon
Could keep the axle on to avoid tax, and make it just high enough to park a lawn tractor under it.
There aren't any axles under it. Clearly laid out in the first post. I don't want it up in the air 3 feet and I could care less about a tax increase. My property is zoned Heavy agricultural in an unincorporated rural area. I maintain an agricultural tax deferral for the farming activities I do here. There's over 12K sq ft of roof on my land and property taxes are about $2k annually. 384 sq ft of trailer is not going to matter in the least to the tax assessor.
Mud
May 20, 2002
South Central PA
I'm a fan of asphalt millings under something like that. It packs solid, water doesn't go through it, weeds don't grow through it, it's cheaper than stone. You can build an entry ramp with it to drive a forklift into the trailer.
I would try to spray the X-members where they are steel to aluminum to minimize moisture/galvanic activity. Many a trailer has failed from X-member rot. Keeping good air flow under the frame will help a great deal.
Around here 'crusher' is the material I would use to sit the trailer on. It may be too late the thing may be in place?
If the nose mount is off make sure the filler is water tight. I would water test the whole trailer myself.
john.k
Dec 21, 2012
Brisbane Qld Australia
In general,loading needs to be supported on the chassis rails of the trailer.......the crossmembers are not strong enough to support more than a couple of tons..............I use concrete piling offcuts to support containers and trailer chassis .....because they are free.........however ,you need to be able to handle the weight (around 1 ton) ,a forklift will do.
Garwood
Oct 10, 2009
Oregon
There are no chassis rails under a trailer like this. The walls form the structure.
I set the trailer on two 2x2x6 ecoblocks at the rear and one at the front just aft of the kingpin.
