One of our suppliers has this machine. They have already had the Makino folks look at it, with nothing past a "gee that's kinda dirty, you better clean it" to show for 3 days work. The Makino guys apparently admit to not knowing much about the machine, and I don't know if the Makino tech even ran through the calibrations.
With nothing to show for that, the owner asked us, being the electronics folks, to take a look at it, so I went over there today.
Essentially, when doing the same sorts of thing in the same sorts of material, using the same settings that used to work, they have had to drastically reduce current to avoid breakage. They used to be able to run at 10 to 15A, now they can't go above 3 with confidence.
Normally, the various things they are doing differently from recommendations would be suspect. But they used to be able to use those settings and get good performance, but now they cannot. Therefore, I am inclined to not put a lot of weight on the differences in what they are doing from what the manual says.
So, what I observed is that, yes, when they get up to about 5A pk current, set at 100V , they got wire breakage when cutting HSS for form tools (they mostly use it for in-house mold and tool work).
Sparking seemed pretty even through a 10mm part (tool blank), standard white sparking that was all in the cut. I did notice that there were intermittent bursts of red sparks, that were more similar to grinding sparks, and which appeared to exit the cut. At that time the cut was only about 50 to 80 thou into the part.
Not knowing so much about wire EDM I don't know if that is normal, I thought maybe not.
They had the wire speed set what appeared to be pretty high, with 20+ inches per minute wire speed. That's higher than the speeds recommended in the manual, and I would think should if anything, be easier on the wire in terms of abrasion/wear. The wire coming out at 3-4A current appeared abraded, but not too far reduced in diameter. I didn't mic it, but the original size was 0.25mm (0.01) and it wasn't a lot smaller by visual check. However, it was not *evenly* reduced, but seemed more rough than I expected.
We tried a current calibration per the manual, but didn't get too far, I suspect the manual doesn't quite apply to this machine. Measuring on the control input (TP310 and 311) while cutting gave approximately 1 mV per amp of current per the setting (about 2.3 to 3.3 mV at 3A set current), but seemed a lot more variable than I expected.
The machine was clean, with no evidence of bad tension, etc. Guides, contact blocks and ceramic wheels had been recently replaced, and were pretty clean. Dancer arm was steady. The mechanical parts appeared to be well maintained, and looked like the book.
Water nozzles were farther away than may be best, but apparently they have run that way for a long time and have not had problems.
The wire broke three times in about 0.1 inch of cut, always at 5A setting. It broke once in the middle of the part, once near the top, and once near the bottom (so it was not consistent in location). The one case that I captured the wire and looked at it, I saw that the wire was very inconsistently abraded. The broken area was thin, with thicker areas nearby, and other areas nearly as thin visible in a space of maybe 100mm (4 inches).
What I came up with is that the current is uneven , possibly from a defect in the control circuits. A noisy part or bad connection in the current measurement circuit could do that, or a similar problem in the current control circuits might also.
Any other ideas or suggestions?
