I'm looking for input from any who has experience getting a VFD drive to work correctly in a hoist or winch application.
We have a small hoist rigged up with an ABB ACS380 drive operating an asynchronous motor. The motor has an electromechanical brake on it and is connected to the hoist drum through a gearbox. This gearbox ratio is low so it will readily backdrive under load. Both the drive and brake are controlled via PLC (brake is operated by PLC directly, not through the ABB drive).
Here's the problem: when the motor is started under load (ie - weight is present on the cable), the motor will backdrive a bit as soon as the brake is released. If the load is high enough this backdrive will run away from the motor and it wont be able catch the load. This is a classic problem in hoisting applications, and the solution is generally to start the drive with the brake closed to build up some torque, THEN release the brake to eliminate the backdrive. For the life of me I cant get the motor to start building torque prior to the brake releasing. I can see a consistent 200 ms delay between brake opening and the motor building torque. This happens every time, regardless of brake-opening delay or any other sort of brake/motor timing. The drive absolutely refuses to build torque if the motor speed is exactly zero (ie - brake engaged). I'm running the drive in vector mode and dont have an encoder on it.
Thoughts on what we're doing wrong? Would the presence of an encoder allow us to build torque prior to brake release? This is certainly a solved problem but for some reason we cant seem to employ it.
