Does anyone have experience running the MSX (or similar) high feed cutters in a Brother. They recommend (for this material 30-35Rc) in the catalog on the low end 260 SFM, .028" DOC, .032" IPT, though via email recommended 200-250 SFM - .015-.020 Feed rate, keeping the DOC shallow. Currently I am running 600 SFM and .003" fpt, .010 DOC (helical), .050" axial. Tool rep recommended " initial starting point would be 400 sfm and .020” -.025” per tooth and keep depth of cut equal to the feed per tooth. So if you are at .025” go .025”, that’s the rule of thumb"
In this application the cutter is 6" from the spindle face, 3" out of the holder (2" length of "cut"). I'm skimming the OD of a hole that is out of concentric and 2" deep. This operation cleans up a 1.625 hole out to 1.850.
Nothing about this job is ideal, but at the moment this is the best tool I have for the job, and I'm hoping someone can tell me I'm being chicken and to crank it up. Maybe it would be better to take a lighter DOC, and take the full width of cut, so the cutter is fully supported? My only past experience with cutters like this was full width of cut.
I will say, at .01" cpt, it sounds like one the shredders at a junk yard they feed buses into. At .005" ipt, there is no spindle load shown.
