Procunier 1E or Tapmatic 30X for deep hole 0-80 tapping in aluminum with drill press
davefr
Jul 1, 2012
OR
I'm toying with the idea of power tapping 0-80 holes in aluminum with a drill press. The thru holes will be about 3/8" deep and pre-drilled to 1.25mm.
Both the Procunier 1E and Tapmatic 30X go down to #0.
My questions is which of these two tapping heads would be more forgiving to 0-80 taps using a hand feed drill press. (Tapmatic due to the adjustable clutch??)
I'm not worried about breaking a few taps while I refine the process. Or am I crazy even considering a tapping head for this
small diameter application?
Thanks!
lazz
Feb 12, 2012
The warm desert of Phoenix Arizona
A taping head could work.
Using a drill press with a tapping heard on small stuff seems a little shaky.
I would suggest a Hamilton taping machine. A 4X40 in a blind hole is easy with this machine. I would imagine there are other machines that could or would even do better.
Nov 19, 2007
marysville ohio
Thanks!
I have done 0-80 with my tapmatic, no problem. I have tapped thousands upon thousands of holes with my Tapmatic 30x. I don't think I have broken 5 taps with it.
