Greetings.
Let me begin by saying I've already investigated this topic on the forums and looking at the brushes on my troubled motor was the first thing I did.
Full Story: Y-Axis started giving me obstruction fault randomly. Eventually it would not move at all, giving me a fault code every time. Here's what I've done so far.
I removed and cleaned 3 out of 4 brushes on the motor. I couldn't get to the fourth one because the encoder housing was blocking it and I didn't know how to proceed. One brush was tight in its hole and much dirtier than the others with a minor chip in the corner. I cleaned them and blew loose carbon from inside the motor with compressed air only.
This part is a bit weird. I swapped the X and Y cables at the ports outside of the drive cabinet. Jogging Y should now move the X and jogging the X shouldn't move, so I thought. This resulted in the X axis moving a little bit and faulting and the Y would still not move.
I replaced the cables back to their correct positions and ran service code 100 for open loop test. I ran this test on X and Y. The X worked fine. The Y did not move at all.
E-Stop is not pressed, machine is lubricated, ways are loose. Pins in both cable connectors look good.
Are there any other tests I can do to figure out where the problem is? I'm going to go mess with it some more. Thanks for reading.
