Hello.
I've made several 12" long barrels, but only for subsonic (Less stress, so hopefully they won't blow up ??)
My favourite is 9X19 Luger. I like quiet 22's so logically four times more projectile at the same speed must be good, right ?
I had a 223 bolt action that refused to shoot predictably straight, now there is only a few thou' difference between their respective rim diameters and that was enough to get me started.
Why 12" long ? In New Zealand rifles must not be less than 30" long and a 12" barrel meets that, also remember it's only subsonic pistol ammo.
I drilled and reamed 304SS to suitable diameter (Don't get all upset ! It's only subsonic so 304 is good enough).
Bought a Ukrainian button and pushed it down the bore using old 8.5mm drill shanks, I'm sure silver steel will be too soft.
It came out beautifully, the rifling is deep and defined, the twist is correct.
Didn't have a chamber reamer available, it's only 3/4" deep so bored it.
Receiver was designed for mid length 223, so had to mill chunks out of it to help eject the short pistol cases.
Mounted a 12" cheapy Chinese (Solvent filter) on the end, I can't buy the material for less than finished Chinese item.
168grain ammo makes some noise (Hollywood has lied to us) but quite acceptable.
Due to the locking lugs I haven't figured out how to fit a magazine and also hand feed is good enough.
This is a good fun, stealthy, 100yard (Max) rifle.
Then I made a 45-70 barrel and fitted to a 100 year old Winchester made British P14 (Don't worry I'm not an animal, the original barrel was rubbish).
Ukrainian button generated a very slow twist, but I still went ahead with finishing and mounting it.
Yes some subsonic projectiles do go sideways, but at 50 yards you get a combination of round and rectangular hole within a 3" circle (Good enough).
Then I made my own button out of an old HS tap and ground straight grooves at an exaggerated angle.
It worked and proved the concept is sound, though not good enough to use.
Got another piece of steel sitting on the bench and hope to find time to get started on the next barrel.
I'm quite happy to provide extra info if someone is interested, but be warned, for every successful barrel, you leave a pile of failures behind you.
Wonky holes, scratchy bores and wrong twist rates could be waiting for you.
Seriously it's probably cheaper to buy a finished blank barrel.
It's been good fun and I've had to experiment and develop technics to get this far, not bad for a grumpy old toolmaker.
