EyeEmTrash
- Feb 24, 2023
I did not see this question posted anywhere so I hope it's not a copy cat question. This is probably an amateur question but it's been so long since I have had to make a cut like this on the OD. Right now my machines are down so I can't even test it out. This pertains to CNC lathe machines. Anyways, I have to make a cable guide roller. The area where the cable will sit in has a .128 radius. It's a half circle. I do not have any left or right hand grooving inserts. My questions are: Do I need them, or can I do it with a straight or neutral insert? If I can do it with a neutral, what is the maximum width the insert can be without messing up the radius too bad? I think the smallest one I have is about .06. In my head, I don't think I'm able to do it but I'm curious if I am thinking about it the wrong way. Thanks in advance.
Edit: so I stumbled across some grooving inserts. They are completely rounded. Here is a link to them https://www.kennametal.com/us/en/products/p.NR.1113217.html
Would I be able to use this instead? I never used this type of insert before but I have them on hand.
