Question about the big Schaublin-102VM lathe
Overland
Nov 19, 2017
Greenville, SC
You're absolutely right! After thoroughly cleaning and lubricating the bed, the saddle now moves smoothly without any issues, making it unnecessary and risky to scrape the ways. However, I have decided to proceed with the removal of the motor, belt, pump, carriage, and other components. This will allow me to fine-tune the adjustable parts and replace any simple components as a proactive maintenance measure. While everything is disassembled, I plan to take advantage of the opportunity to apply body filler to areas that require it. My ultimate objective is to restore the machine to its original color through repainting. I should note that I will not be removing the headstock, as I understand it is considered almost a crime against humanity due to its importance and significance in the functioning of the machine.
If you are going to remove the motor, etc, this would be an ideal time to replace the motor to run on a more easily available power supply.
I don't know the details of the Montreal power supply, but in the States, 220 volt single phase is the norm for domestic supply.
Maybe your best option, if I'm correct on the 220 volts, would be to get a 3-phase 220 volt motor (easily available) and a quality VFD, such as a Fuji, to power your lathe.
Bob
jim rozen
Feb 26, 2004
peekskill, NY
Post a photo of the motor nameplate when you can. It might possibly be re-wired for a lower voltage. It's a two speed motor but a 240 volt 3phase motor run off a VFD will emulate that very nicely.
May 29, 2023
Bob
I am thinking about a servo
May 29, 2023
couple weeks now bit cleaner
Ralph_P
Jan 14, 2003
E. TN USA
The mounted tool holder looks like someone was using it for a spindle brake. Some of the MT shanks look like someone used Vise-Grips on them. Otherwise it looks good.
