As anyone who has tried to design a machine from the ground up would likely know, you quickly end up having to think about it from a dozen angles simultaneously and slowly shake the final design out over time. I appreciate the constructive advice you and others have provided, and am definitely feeling the hard learning curve here!
-I expect to hold 0.003+/- from "zero" over the long axis of the workspace but that number can be flexed a little if required by my materials. The key with this machine's heavy construction is less about needing supreme accuracy, but more about reliably and safely cutting steel long term. I see a lot of these hobby mills that can barely cut aluminum, and I really want something to cut steel with. I make a lot of projects requiring precision reamed holes in steel/Ti to line up perfectly, and I am also looking at some future work where I may be cutting some loose pneumatic cylinders/ piston heads. I just don't want to have to worry about my cheap Chinese linear rail slopping over time.
-Speed is also of minimal concern to me as I already spend more time than a mill would one hand sawing, filing, sanding, lapping ect. Slow is okay if it means I get nice cuts.
-Damping is only required as far as a safe and consistent cut is concerned, this machine will live in my garage so noise is less of an issue.
I have a very rough CAD drawing of the most basic layout right now that I will throw up here soon.
Please try over at "the zone".
Posting a linky for that site here, is not allowed (weird forums rules)
try www. seeandsee zone.com
Make the obvious changes.
