Questions from a newbie about a new Vert Mill (BP clone). Easy stuff...with pictures
John Madarasz
Jan 1, 2007
Exton, PA.
Regarding rancid coolant problems...i've used this stuff with good success, so far over a year in the tank & no stink ever, no rust ever and it sits without being circulated for weeks at a time sometimes. Fairly non toxic, ecologically low impact and completely non carcinogenic too. I almost positive this is ITW's stuff that used to be called Rustlick.
This little 3 gallon system is also from enco...cheap and works good...and you don't have to foul up the inside of your machine. They have them on sale all the time for $89.00.
I machine a lot of copper on the Bridgeport and on my 12x36 lathe so collecting chips is important for scrapping. FWIW I have a little dedicated wet/dry shop vac for each machine. That way I can suck up chips in a very wet environment...and it's great for end of day cleanup too...sucks all the coolant out of the table resevoirs and slots before I blow everything off and wipe down. I just rake and scoop the big piles out of the lathe first. When the shop vac is full...pop the top and dump chips and coolant into a 6 gallon bucket with holes in the bottom that drains into a oil change pan, then pour the leftover coolant back ibnto the system...works pretty good for me in my low/medium production environment.
Shop-Vac Mini
gwilson
Oct 1, 2006
williamsburg va
I use a shop vac. also for collecting chipsObviously this is not the solution for those who generate large volumes of chips,but for small amounts it has worked just fine for many years.I wanted the newbie to be aware that he can't use just any coolant that comes to hand.if he's starting from a complete learning position,he needs to be careful.The above post on coolants will help him.
Bluejeep
Aug 3, 2006
Cape Cod, Ma
If you do find you need to use a recirculating coolant, Doall's Powercut 390 is a good coolant thats never gone rancid on me, I've been using in my lathe and kneemill for 10+ years never had a problem with smell or rust even when not used for sometimes a month or more. Though it does grow some slime that I just skim off occasionaly. Hocut 795 also works well,(I've been running it in my vmc for 3-4 years) no slime, but you have to keep up on the concentration to avoid rust.
dsergison
Oct 23, 2003
East Peoria, IL, USA
Can you share any advise about making the ball tracks? I always wanted to make a ball coaster myself.
I was wondering what sort of wire do you use and if you have any tricks for forming it. I assume you form it to close shape and then then weld seperator ties as you go.
I wanted to make a grown-up toy kit with machined ties and using bulk wire. somehting reqireing no welding, just an allen wrench. I think I can have a ton of the braces waterjet real cheap.
green frog
Mar 9, 2001
Lynchburg, VA, USA
Hey Hokie, you might also drop by Mason Mechanical over near you in Salem. They are fine folks and can provide you with tools and (I would imagine) proper lubes, etc. No connection, just a somtimes customer who is always helped.
Green Frog
Johann Ohnesorg
Dec 7, 2005
Germany
Hy,
I would get rid of the red goo asap. On my machine, it was loaded with grinding dust, wood particles and chips. It wipes off with petroleum or lamp oil...
What about a mist coolant system, oil/air does well if you´re using the machine now and then and you have no problems with staining by or rancid coolant.
Cheers,
Johann
