Hello everyone,
I need a little help regarding a Deckel S0 dbit grinder that I recently bought...
1) The scale of the collet holder does not match up with the indentations on the index plate, they are shifted ~2-3° to one another. The second picture shows the collet holder in the locked position and it is also not matching up with the 0° mark. Is this on purpose? If not... it seems that the index plate and scale are press fitted on the same bushing so I'll have to make a tool that goes in two of the grooves of the index plate so I can try and rotate it a bit on the bushing?
2) The grinding wheel mount the machine came with is definitively homemade and not original, also when I compare it to a cross section of the original one, there seem to be parts missing. Can anyone share the dimensions of the grinding wheel mount, washer and nut for the older Deckel S0 version with the cylindrical spindle nose?
