I'm considering purchasing an a51nx for some upcoming aluminum jobs and have a few questions I'm hoping those who have been down this road can answer.
1. I have friends running 400mm Mazak and Matsuura HMCs on 6" slabs with no trouble. I read 300mm is the recommended thickness from Makino, which I am inclined to follow. I've also read the secondary benefit is the isolation from the rest of the floor if running other machines in the area. Are any of you running an a51 on a thinner floor (4-6") without (known) issues?
2. IMPORTANT TO CONSIDER MACHINE OPTIONS? If you did it again, what options would you order (or leave off)? I'm looking at a basic CT40 machine with a 60 tool ATC, 300 psi, workpiece probing, and a tool laser. Parts to be machined resemble shoe-box geometries and iPhone-size parts, so quite the spectrum.
3. How well does the vision tool monitoring system work?
4. In hindsight do you feel the 300 psi coolant system is okay, or would you spend the extra ~$18k for the 1000 psi? Have any of you had the upgrade field installed, and if so, were there any unforeseen issues?
5. Are there any controller / memory / work-offset options that should be considered before buying?
6. Are there any conveyor options that work better for primarily cutting aluminum?
7. How complicated was the controller to learn for someone experienced on Haas and Mazak machines?
8. Has anyone had a larger tool magazine field installed, and if so, were there any unforeseen issues?
9. Does anyone have experience with the more affordable a40, and if so, how does it compare to the '51?
Thanks for any feedback and opinions you can provide. I'm just trying to have a solid list of questions before sitting down with my regional sales rep.
Mike
Mike
