rabler
- May 25, 2020
- Rural S.W. Indiana
Hey folks
Haven't been on here much in the last year. Just posting a personal update, so this is more social than technical. I think that is within the forum rules. I'm posting in the Monarch forum as that is my primary interest in PM and where I've posted the most previously. My use is strictly hobby oriented so I'm trying to tread a bit carefully, these are certainly not hobby class machines so I think I'm Ok.
I own three different Monarchs, a 1944 12"CK, a 1967 612-2516 x 50, and a 1964 Monarch 10EE. The Monarch 12"CK is my regular use machine at this point, I've really gotten to like it. It fits my needs nicely. I rebuilt mine pretty extensively, added a VFD (mostly to avoid needed 3 phase) and a DRO (DroPros). I have it pretty well accessorized with tooling. The motor has been replaced, from 1200 RPM to 1800 RPM, so I have a bit more than "stock" RPM, with the VFD I can get up to about 1000RPM if necessary, but usually run it with the VFD set at 60Hz so I get about 800 RPM max (vs about 550 stock), and use the gears for RPM selection.
The Monarch 612 is running and I use it occasionally. It's really a beast of a lathe, and it has the RPM range to run up to 1500 RPM (stock). I have an RPC that I use to power it, as well as powering a K&T 3K vertical when I use that. The RPC actually uses the original 20HP motor from the 612, I downgraded it to 10HP. I need to do some work on the carriage oil system of the 612, for now I need to manually oil the back way of the carriage when using it. That lathe originally had an Electronic Tracer (ET) with a motor and clutch on the back of the cross slide leadscrew, and that motor drove another oil pump. With the ET long gone, the motor is defunct. This lathe doesn't have a DRO, I'm considering the TouchDRO option to try out on this.
The Monarch 10EE is half way rebuilt and a pending project. I started working on the DC motor, which is a mess with internal wiring losing the insulation. I had built a digital front end to control a Parker 512/504 system, but went to far down that path before realizing how bad of a shape the motor is in. The motor mounted reduction gear box is also almost worn out in one of the gears. I've replaced all the bearings, but the wiring and gear is pending. At this point I'm torn between pushing forward with the DC motor vs. throwing in the towel and going with a modern motor and VFD with the reduction gear included in that. I know that topic can spark some hot debate, not really looking for input, just rambling. But I want to get back to this.
I spent much of 2022 getting a new shop built. 40x56x12. A hobbyists dream shop. Worked quite a bit over the winter to build a digital monitor for my RPC output, so I can log voltage and current on each leg at 1/2 second intervals. Using a microcontroller and FFTs to analyze those values as well as noise levels on each line. Sort of the finishing touch to the shop, I've been building a bridge crane to go in the back half of the shop, getting closer to finishing that. Some of the bearing fits and other details of building that have gone a long way toward testing and honing my machining skills. I'm also working on rebuilding a Tree 750VMC, gutting and rebuilding the control electronics. In short, my shop is a project
Unfortunately this year has been fraught with medical issues so progress has been slow. Just glad to get out to the shop when I can. When I get around to more refurb/improvements on the Monarchs I'll update the old threads here.
edited: thread title per Cal's suggestions
