only_wallace
- May 22, 2023
The coordinates of the OP's program show two arcs with different centres, therefore, unless the OP has made a mistake with the coordinates, the two radius features don't form one continuous arc.It looks like you're trying to do a full radius on 3/4 key stock. If that's the case try this:
Both quite possible.The 1st rad, you're moving .500 in Y while trying to cut a .43 rad.
The 2nd rad you're moving .500 in X while trying to cut a .43 rad.
diameter offest #28, it's called with the G41 to either add the cutter geometry and/or wear.also whats the D28 code for?
This looks useful; ill give it a try. Thanks.It looks like you're trying to do a full radius on 3/4 key stock. If that's the case try this:
G0G90X1.Y.76
G1G41X1.Y.375F5.
G2X1.Y-.375R.375
G1G40Y-.76
This is assuming that you have .375 radius or less in your tool offset.
That shit worked!This looks useful; ill give it a try. Thanks.
You're right, I was thinking of a quadrant, not a half circle.Both quite possible.
Regards,
Bill
Notice
