nlancaster
- Oct 8, 2018
This part is glued up titanium and ceramic, cut on our Sodick AG600L
Grounding clamps connect to all parts that are being sperated.
We WEDM the ID to .1574+/-.0005.
We then separate all the segments.
These should have sharp corners at the ID for each segment.
Mostly they do, but we seem to get way to many of them where in one section, not the entire vertical length, of the corner looks like it has had random arking and erosion on it.
Sodick suggested increasing tension and decreasing Flushing pressure but it still seems to have the same issue.
Bedra Cobracut TypeA zinc coated .006 wire.
New diamond guides, new carbide contacts.
Water is at 100,000-110,000 ohm/cm3 resistivity.
Filters are fairly new, with low but constant pressure on the gauge while filtering.
In the past we have tried increasing flusing pressure, flushing only from the top or the bottom.
