I'm having random non starts on a new build 15hp RPC. Fitch style but with a timer for cap disconnect. It now has 1000 uf worth of starting caps with bleeder resistors, no run caps yet. Starts in 1 sec. (When working properly.) Tried about 800 and 1200 uf but no difference in failures. Occasionally on start the idler motor shaft just barely wiggles and never really rotates. This may happen maybe 1 in 4 starts. After a non start it may or may not start after that, everything from 1 to 3 non starts in row have happened. When it does start everything is perfect. Both start and run contactors have 220 on the outputs and both main motor leads draw just under 200 amps and the 3rd about 65 amps when this happens, only slightly higher than when it does start normaly. All these readings are max hold on a Fluke ammeter. Fed with a 60 amp breaker, never tripped it yet. Leeson motor is used but megs good and all windings read the same with an ohm meter, runs quiet with good bearings. I'm leaning towards a bad motor but not much to go wrong there considering the way it checked out. Any ideas?
Thanks
John
Thanks
John
