Back facing is something that I have rarely done in toolmaking. I would lock the quill & use the knee for control.Is there any operation that would require you to raise the quill quickly or against resistance?
Back facing is one possibility. What if you are drilling and the drill grabs?
I would be circumspect about relinquishing bi-directional positive control of my quill.
I always try to avoid setups where a drill could grab.
Thanks for the tip.The idea is good. It would benefit if it evolved into the Mk 1.5 model that allows you to lock the two parts together when required.
I am giving you a free idea for another YT video (more views, more thumbs up, more like, comment and subscribe) that you can post around the fora when it is ready.
Not a fan of the quill being susceptible to being sucked into the work OTOH some kind of fancy engaging mechanism that can be switched from lock to a ratchet return going up and down might be pretty cool. Then the handle can mostly stay secured on the quill feed speed, so it doesn't awkwardly fall off or get in the way.
I want one of these for my Wells 747.They already make a setup that works great. Pull the handle away from the machine to pull engaged face drive pins out of a hub. Reposition, and let the handle pivot back and they go right back to providing positive engagement.
Ed.
When working quickly and accurately, a reliable position of the handle is needed. Drill 50 holes where the handle does not return to the same spot every time, that handle is in the bushes in a heartbeat.
Now, that said, I like the thought. A nice 40 tooth spline with a pushbutton so it only slips on the up when I want it to. does not have to be strong as the sprag holds the force. The pull out action and coarse pitch of the handle like eKretz and most of us have makes it less than perfect
Notice
