I have a EMA/Casadei F115,mfg 1989, it has sat unused for 20 years or so. It was a production machine. A nice heavy machine, needs some TLC. Spindle bearings are free, but dry, and a bit noisy spinning by hand. I want to pull the spindle out and replace the bearings-
It looks like the top bearing is retained in the housing by a cap of some sort- there is a top ring that turns with the spindle called a "fan", it has little rubber vanes on it, and under that is a cap for the bearing , I assume it is either threaded or bolted into the housing.
I was thinking about pulling the housing (the spindle and spindle housing (quill?) not the cylinder it all fits in) out and working on it on the bench, but maybe it can be left in the machine and worked on in place? Any ideas? How to pull and drive the bearings with no damage? I never took one of these apart before.
Also- the motor is hard to turn by hand on the pulley- the manual says it has an electro-mechanical disk brake- is this why? It has to be connected to power to release the brake?
