Overland
- Nov 19, 2017
- Greenville, SC
Was thinking something like that, but whenever I've tried to grind cast iron it was very slow. Is there a particular type of wheel grit I should get ?Use a 9" grinder and a larger cup wheel, 6" dia or so, hold it flat to the surface and have at it. The cast iron will grind easily so make sure to get a good feel for before you get down to the good surface level. In other words grind in passes over the entire high area a little at a time with each pass, DO NOT start at one end and grind down to full depth and then go along the length at that depth.
Sometimes you take a risk at an auction, based on the poor photos listed...........One wonders why you bought it like that if you don't know how to fix it.
You could do some preheating and try to build the low areas back up.
But my vote is to cut a piece that pretty much fills the void. Then use it with or without your filler piece. I'm guessing you'll either learn to live with it or you'll get sick of it and find another fool.
I'm very surprised you'd say that from what I've seen.You can get a 5x5 for around $1500 here in the midwest.
The guy at Sullivans said grinding cast iron very slow. He was thinking 3 to 4 hours at $400 an hour on his Blanchard. Economics don't make sense to me.If it was mine I'd pay to take it to the Blanchard. The big machines would eat that in less than 15 minutes of spindle time, the rest is all handling.
If time had little value to me, I believe I would make a sled to use my 2 x 72 belt grinder and grind under a contact wheel. Those 24 grit belts will really move metal and with a proper sled you could easily get it to within welding table flatness.
The picture of the rail showing how much the table top was worn is interesting. I've never seen a table with that much wear. My guess is when they set it up on their boring mill they either ran out of travel, or didn't want to reset the clamps.
Somebody's thinking - "might could work", as we say in the South.Is that table the same thickness or are the edges thicker? If all one thickness what does the bottom look like, maybe you can just flip it over?
Decent platen tables here in Ca are $2500 ballpark.
Radial arms saws have all the rigidity of rubber in the vertical direction, bad idea.Maybe bolt a radial arm saw to the casting and use a grinding wheel instead of a saw blade.
Bill D
Notice
