you may need two ovens
In case not aware , FYI low alloy steel heat treating
to hold hardness 30-35 HRC has to austenitize , quench & temper, temper must be with in one hour or it will crack
austenitize temp = 1650-1700 deg. F
quench in oil or water (I recommend oil less distortion)
then temper at oil -1050 +/- 25 Deg. F , water = 1100 +/- 25 Deg. F
see ref link : AISI 4130 Alloy Steel (UNS G41300)
to anneal = 1515 +/- 25 Deg F then air cool
see post #18 at the bottom I added an edit with the correct procedure for pack carburizing.Ok, so I guess I should ask this question......I could either make these parts (teeth for compact tractor toothbar) from mild steel and case harden them, or I could make them from say 4130 and do normal hardening. Any feel for which may be cheaper?! I thought case hardening may be cheaper, plus a little easier on the end mills when milling but I may be wrong.
If I do case hardening, any recommendations for compound? I've seen a lot for Cherry Red. That's where you pull the part out hot and dunk it in it, correct? That stuff work ok? Or, again, I could try charcoal and bone char. I don't care about the finished color. Just trying to find low cost method and material.
thank you yep it's from years of experience.1953chevB,
I forgot to respond to this. I appreciate the info. I'm aware of the process of going from perlite to austenite and then martensite, then tempering to change the carbon 'needles' in the martensite. I'm just not experienced with actually doing it so I really appreciate the numbers, i.e. temperatures, times, etc. THIS IS WHAT THEY DON'T TEACH YOU IN ENGINEERING SCHOOL!
Also, I followed your link to AZO Materials. I like this site! Look up any metal and get the specific temperatures you need. Thanks a bunch!
Your Welcome1953ChevB - I appreciate the info. I did basically exactly what was described in post #18. I pack carbonized in a box in the oven with a commercial compound. Had to post-heat treat since you can't get them out of the box until they cool so they basically get annealed. After hardening and tempering, they came out really nice. They have a good hard case to I'm guessing 0.040-0.050"
These teeth are for small compact tractors. The teeth themselves are small as noted, triangular shape with base being 3.75in, hieght being 2in. So they're not for super heavy duty operation. They can also be easily replaced. Hence, I thought I'd try case hardening.
I've just found that the compound isn't very cheap. I know you can re-use it when mixed 50/50 with new stuff. I'm still experimenting and wondering it I can find a cheaper compound to use like bone char and basic charcoal but I know I won't get as deep as casing. Other options are to a) as others suggest, weld a surface onto them or b) Go to a harder alloy. Just seeing what everyone thinks. Feedback has been great. Thanks a bunch!
Notice
