Posted same time again lol.
DT may exist, but DG (universal) is what most places would stock and is "better". Its not the same as the DT cant go in any other orientation than tandem, and its because they didn't hit the tolerance on one or both of the bearings race face to make it the same as the others and therefore universal.
You're somewhat backwards on the pressures. You do not want to push on the outer races to push the assembly out, (springs could collapse and separate the rear bearings) you want to push on the shaft with the bearings staying under tension by the springs. The risk there is the fit of the front bearings to the housing. Thats why we say its risky, there is no way to take this apart and mitigate all risk.
