michiganbuck
- Jun 28, 2012
- Mt Clemens, Michigan 48035
I just answered a private message with this..If any PM Members have something to add please do so.
Buck
At the big shop, I used a bar with it having a double precision bearing to intersect the taper at two places so acting like a floating steady. I could grind a center point off the taper to a few millionths of dead on center..But the setup was not very safe so I don't recommend anyone doing the same. Set on a brass or bronze double would be much the same.
Your Studer S20 should have a #4 in the headstock so I would purchase a #4 to #2 Morse taper and just grind your points out of the headstock by turning the headstock to angle., perhaps using a lathe fish gauge for an angle template. Good to have/use a Norton center lap point mounted wheel to lap your part center before setting them on your machine center so to have less wear on machine centers..
One can rough grind parts on a live center, then finish grinding them on a dead center, perhaps buy a Royal live center(or the like) if 50 millionths to one-tenth would be close enough. A common live center with ,0002 error you can expect .0004 on your parts so such belongs in the dumpster.
Let me know if this was helpful, Buck
Buck
