We have a Reid surface grinder from the 60's. It uses a single phase 220V motor to move the table from left to right. The machine was run out of oil which caused the motor to overheat. The motor was rebuilt, and the machine left in pieces from the previous maintenance tech. 6 years later I get to try and finish repairing it. The surface grinder reverses the motor to change the tables direction. So, every pass under the grinding wheel the motor will reverse. The electronic circuitry has been modified from original. A capacitor of some sort has been added, or maybe it was always installed, I can't tell. It looks like it was added later inside the electrical cabinet. The motor has no centrifugal switch for a start capacitor. It has 6 wires in the motor; 1,2,3,4,5, and 8. The motor tag doesn't show a wiring diagram so I'm assuming (3,8,2), (1,L1), (4,5,L2) and swap 8 & 5 to reverse. How is a capacitor supposed to be wired in if there's no centrifugal switch to turn off the capacitor? This seems like a very strange design. Constantly starting and stopping and starting the motor. Any help is appreciated.
