Removing gas nitride residue from stainless
Comatose
Feb 25, 2005
Akron, OH
We have a family of new parts made of 400 series stainless, that have to be hardened and then gas nitride. They come back incredibly hard (1300 vickers!) but with a mottled yellow-grey residue all over them. The residue doesn't wash off with the usual things I have tried (simple green in ultrasonic, citrisurf) but it does come off if I bead blast it. As received versus after bead blast in the picture. Alconox in an ultrasonic makes it better, but not shippable.
Bead blasting each one is a lot of manual work, though, and I'll need to make about 50,000 of these.
Does anyone have any idea what exactly this residue is and how I can remove it in a batch or no-touch process? My heat treating shop doesn't have any insight but they're a pretty small operation.
Thanks!
John
Comatose
Feb 25, 2005
Akron, OH
Oh, and it's not baked on coolant: I sent them one batch just rinsed in DI water, and one thoroughly degreased and then double rinsed in DI water and blown dry, and they both came back looking the same.
henrya
Jun 25, 2008
TN
How about a fairly strong citric acid bath as if you were passivating them?
chipss
Jul 19, 2020
Any surface finish requirements? Run them through a fine particle vibratory bowl polisher?
FeinMecanix
May 8, 2020
air leakage on cooling can lead to discoloration. try another heat treat shop and ask them if they can guarantee non blemish finish...
Thunderjet
Jun 24, 2019
We glass seal some larger (for us) parts and have had to rethink our oxygen purge operations. We were getting a similar but not identical reaction from our ovens.
You may try to ask about maybe a vacuum H.T. option from your heat treater.
Just an idea.
