Hi all,
I've got a HURCO VM10i and the Renishaw part probe is out in Z by -73.8104 mm! I was in on Friday and used it with no problems, came in this morning to finish a few things off. Started the day probing the part to engrave a serial number and it tries to put the tool through the part! Lucky I never fully trust the machine until the offsets are proven so other than a bit of a gouge in the part which will hardly be noticeable once the engraving is in and a chipped engraving tool it's not so bad.
It's worth noting that no one has used the machine since I powered it down last. I took a tool and touched off of the tool setting probe then set machine zero in Z by touching off a gauge block. I then ran the probing cycle on the gauge block and the difference is -73.8104 mm.
I've changed the batteries in the probe and restarted the machine. Not sure what else I can try so any suggestions will be welcome!
I'll give HURCO a call on Monday if I can't get it fixed but I've got some parts that I need to get finished this weekend so it would be really handy to have it working!
