Replacement for CL46 oil for MAHO MH600C
kowal256
Dec 19, 2021
Hello,
I bought old MAHO MH600C in pretty good condition and I got it running (with few minor things left to clean up).
What oil do You use for lubrication of your MAHOs? Manual calls for CL46 and CGLP 68.
CGLP68 is readily available, but I cannot find CL46, what's the modern equivalent?
I posted this buried under some other questions before in the wrong section here (Maybe I will get better luck in MAHO specific forum :P): https://www.practicalmachinist.com/vb/cnc-machining/bought-maho-mh600c-looking-some-tips-397790/
DrimJohn
Jul 12, 2017
Hard to imagine that pretty much any normal ISO 46 gear or hydraulic oil would not be just fine, like Mobil DTE Medium or DTE 25.
I had the same problem for my machine, it states CLP46 or CL46 but when i googled the recommended oils i found out that they were ordinary hydraulic oils.
