macona
- Jun 20, 2006
- Beaverton, OR
I mentioned in an earlier thread that I am converting my 10EEs drive from motor generator to AC Brushless Servo. Finally have gotten started on it.
I now have all the parts for the motor. I am using a 2kw Mitsubishi Servo with a 3.5kw control. Got the control, encoder cable, and the motor off ebay. The motor appears to be brand new, no marks around the holes from being mounted. The control was sold as having been repaired a year ago and sitting on the shelf as a spare. Went to power it up and it went boom! Opened it up and it had been repaired but whatever this drive was installed on corroded some of the PCB tracks in the DC Bus and it flashed over. Cleaned it up, installed new caps, and sealed the board and it works like new.
The drive is intended to be operated with three phase. So while I was in there I changed the caps to a higher capacity. This combined with the drives ability to run on Japanese 200v mains I think I should not have any problem driving the smaller motor.
Last week the special interface connectors showed up. Got the drive running in velocity mode. It also has a position mode where it will accept step/direction signals to control the motor. In vel mode it has a max speed of 2100 RPM and with the pot I am using 8-9 RPM minimum. Incredible power at slow speed. Guess thats why it has that 35mm dia output shaft!
I have decided to direct drive the back gear. If I need to get that extra 400 RPM I will make a larger drive pulley for the gearbox. Or snag the 3000 RPM version of this motor if one pops up on ebay. Today I drew up the adapter plate that will adapt the gearbox and give it a mounting face identical to my servo motor. It will hold the input bearing, oil seal, and drive shaft.
I happen to have a plate of cast iron that will be perfect for this. about 10"x10" and 1.625" thick. I faced it off on the mill and it looks good. Going to make the drive shaft from a piece of 4142. it will be hard coupled to the motor. One modification from the original design is the addition of a pilot bearing on the tip of the drive shaft that will run in the output shaft of the gearbox. This will allow me to use other coupling methods than a hard couple if I have problems. Also I can belt drive the gearbox if this dosnt pan out.
Heres some pics of what I have going so far. The first pic is of the motors I have. The motor I am using is the one on the right. To get an idea of size the shaft is 35mm (1-3/8") and the flange is 176mm sq.
The other pics are of the design of the adapter and the facing of the cast iron.
