RFQ Ø140mm Cylinder end / Clevis
tonymor
Member
We're currently welding these and machining afterwards. Would much prefer to buy something machined from solid.
30pcs/month. We could buy 60/120pcs at a time.
Cylinder end is Ø140mm +-1. so I believe 5.5" bar would work.
Material 1018/1045 or something similar.
Hole is 2" +.005. 2 tapped holes either side 3/8-16 UNC
Preferably a shop not too far from South Central PA.
Milland
Active member
Unless that's a very low-stress part, I'd suggest you add some large radii to the transition between the two sides and the base.
Ox
Moderator
Not sure that a print is needed for a quote for most folks, but they would need a length to figure from.
Think Snow Eh!
Ox
Milland
Active member
The graph isn't perfect in the first pic, but by estimation the slug length should be about 6.5", and the part a little less.
tonymor
Member
RFQ closed. I have gotten some good feedback that I won't get anywhere near my target price to make this work.
I'll just have to keep welding and post machining for now and look into forgings/casting down the road.
Thanks all.
david n
Active member
Making that part from solid bar is going to eat up a lot of machine time. Could it be made as a weldment?
Go back and read the OP's request..............................wants 'em from solid..............................
Wonderin' if'n they got 'em sourced and ball park $$$?
Ox
Moderator
Thanks all.
Think Snow Eh!
Ox
DDoug
Active member
Kind of wonder what that target price is ?
And compared to the cost to burn, weld, anneal, and machine currently ?
LexD
Member
Thanks all.
Did you honestly think that machining them from solid bar would come close to the price of fabricating them?
