Ridge in rifle chamber
Northwoodneil
Mar 30, 2023
Hi long time lurker first time poster, I recently purchased a Winchester 1885 in 32-40. It had the barrel relined and looks like a professional job. Upon trying to chamber a round they fit really tight and didn't want to extract. I coated the cartridge with Dykem and when a shell was chambered and knocked out of the chamber it has a bright ring 1/4 inch from the rim. The Dykem left a corresponding ring in the chamber. The ridge is maybe a few thou. high. It's like who ever chambered the rifle had a chip in their reamer. Can I lap that out with an abrasive (like valve compound) coated empty casing (cut off just past the ridge so I won't mess with the rest of the chamber) or do I have to rent a reamer?
john.k
Dec 21, 2012
Brisbane Qld Australia
Yes ,fit a 1/4 rod into the base of a case ,split the case into four fingers ,embed some 400 grit into the brass ,was off excess ,and hone with kerosene as wetting agent..........obviously the base is a bad spot to enlarge ,but needs must ...........I assume you relined to preserve the originality,so wont want to set the barrel back ..........In a 32/40 ,a slightly larger case like 303 may make a better hone.
Northwoodneil
Mar 30, 2023
Thanks John. I made a lap from a 32-40 case filled with cerosafe. I turned the rim off of it and center drilled and tapped it to fit on an old cleaning rod. By removing the rim I won't deepen the rim recess by accident changing the headspace. I shortened the case to go past the ridge by about 1/8 inch. I haven't tried it yet, I wanted to hear what the metal magicians said first. I was thinking a fresh reamer would clean up the ridge but didn't want to pull the barrel.
john.k
Dec 21, 2012
In general ,to lap a conical bore (your chamber) you must have a spring lap ,that will produce a crosshatch pattern.........if you attempt to use a solid lap ,you will groove the surface .......to make a spring lap ,split the case into four and lever the fingers out a bit .....charge this with grit and use kerosine .....if you lap dry ,the lap will 'blind ' and score the chamber.
FredC
Oct 29, 2010
Dewees Texas
PS a reamer wont get you anywhere ,unless you rechamber for a bigger base ,say 30/40 Krag or 303 .....neither of which have a 320 bore.
Curious why a reamer would not work. I built a 35/40 and the reamer manufacturer made it too small just ahead of the rim. I sent the reamer back 2 years later with sample cases. They acknowledged their mistake made the new reamer. I made a thin brass disk to ride on the reamer to keep from deepening the rim recess and changing the headspace. I made an extended driver and reamed though the receiver. It turned with a little resistance till the brass spacer touched the barrel, then spun freely. The cases fit now and the spent cases extract easily.
This was done years ago, but I think I see the brass washer in the chamber before I cleaned it out.
john.k
Dec 21, 2012
I m interpreting the OP as saying the chamber has an imperfection caused by a chip stuck in a reamer ...which I would think was a groove .....not a raised area..........Now you would think I would learn not to offer opinions on things I have not seen .....
FredC
Oct 29, 2010
Dewees Texas
Well, it is not like I never misinterpreted an OP's question.
Nah, I have never done that more than once a day.
If the OP did indeed have a groove in the chamber wall, your answer makes sence. Since this has come up the OP might run a smooth probe along the chamber wall to verify which way it is. I hate the idea of having to clean lapping compound out of an action, the stuff kind of gets everywhere.
cyanidekid
Jun 4, 2016
Brooklyn NYC
haha! well that would put you in the minority here by a wide margin...:D
Northwoodneil
Mar 30, 2023
Well my lap worked for me!! The lapping compound took a lot of size off my lap as I worked it which I think worked in my favor by letting me move into the chamber farther eliminating any ledge. I started with coarse compound for a short time and this roughed up the lap to hold the fine compound really well. I made another 1/2 chamber length lap and did a final polish with simichrome paste. Clean up wasn't to bad I cleaned up the big stuff and let the ultrasonic cleaner get rid of the rest. Thanks all. Neil
