WILLEO6709
- Nov 6, 2001
- WAPELLO, IA USA
Frank, I personally would not hesitate to unload those lathes myself, but I have moved several machines similar so I have a plan of attack. I think you could get the job done, but at what point is it counterproductive? Safest way, hire the rigger, pay attention, get over your fear by seeing it done. Most of the time with the right equipment its more just being careful about pick points. Your 12k forklift counts as the right equipment, but the weather adds a glitch that may be your main obstacle. one word to the wise: kitty litter. Spread it out on the ice where you need to drive, works wonders for forklift traction, loose small gravel works too put on top of the ice. If you have straps you can loop around the bed sections and lift from the top it should swing easy, but many a lathe has been picked under the bed with proper blocking to protect the leadscrews and drive rods. just position for a level lift and don't have it any higher off the ground than required to clear. Get it low as soon as you are clear of the truck, and drive easy. Your call, let us know how it works out.
