That Reeves does look beautiful though. Do you think it runs as smoothly as when new or does the design just not compete with your vfd conversion? As I recall you did about as high end conversion as possible, TENV vector motor, new attachment for the gearbox, very high end vfd, and new pulleys for low end torque. I would bet not many 10EE vfd conversions are comparable. Dave
I do believe the drive in my Rivett is restored to nearly new condition. I replaced all the bearings in the drive, re-faced the Reeves drive pulley shivs, and then balanced them. I reground the surfaces of the magnetic brake, re-wired everything and replaced the friction plate. The drive works well and is reasonably quiet and usable. However, there are a few short comings and inconveniences of this drive that I believe could be corrected by a good quality VFD conversion.
What I mean is, at the high end of the speed range the Reeves drive does produce vibration and noise from the pulleys and belts. Additionally, braking with the motor brake is a less than elegant system for what is a very elegant lathe. A VFD would improve both of these in performance and smoothness.
One other annoying feature of the this drive is if you are in the low end range of the direct drive – say 1,000 RPM – and your next operation requires you to go to the high end of the back gear where you need close to 400 RPM, this requires you to accelerate the drive all the way to get to this range. Then if the next operation requires you to go back to 1,000 RPM, you must decelerate all the way back down. This can become annoying and time consuming on the Rivett but would be a very simple and quick operation with a VFD.
And the last observation I would make is when the machine is running at high RPM, especially with a 6” forged chuck installed, accelerating from zero to 2,500 to 3,000 RPM is a lot to ask of the clutch when the drive is running or the motor when the drive is not. With a VFD this would be a smooth and simple maneuver.
Your point about my VFD being a high-end conversion is noted. And, yes, all VFD’s and conversions are not created equal.
