akerman
- Feb 6, 2007
- e. peoria il.
Now you can get 4 as it's half off! walk don't run!!! lol.Does he have another? At that price, I'll take two!
#275 should have been built in the year 1955, ( only 6 model 1020S built that year) which is prior to the change to the exposed bolt pockets in the headstock (lowering cost). There were also three distinctly different tailstocks over the years.SN is 275. 1962 build year. What features are you referring to?
That date seems odd due to the early headstock.I have Carl's old machine as well, he did a wonderful job with the repair!
I just double checked, clearly stamped 275, 1962... see photo attached.
Also interesting that the chart only goes to 1961 and my machine is dated 1962....That date seems odd due to the early headstock.
Mine is S/N 381 dated 7/21/1960 which lines up pretty well with the serial number chart:
RIVETT LATHE SERIAL NUMBERS
www.deprecision.com
Rusty,This is a later headstock. you can see the bolts that hold the headstock to the bed.
The early headstock bolts were located underneath the bed.
To get to them to remove the headstock you have to remove the gearbox.
beautiful restoration!! do you have a write up of the restoration anywhere online?I believe my machine is a 1961 but not sure. I’ve posted the machine’s data plate and a picture of the headstock.
As a side note, I pulled the headstock on this machine during the restoration to change the spindle bearing. When I went back with the headstock, I oiled all of the mating surfaces and carefully shaved off all the excess with a razor blade to ensure no contaminants.
When I had the headstock on, I installed all the headstock bolts and lightly torqued them. I put a .0001 indicator on the spindle both vertically and horizontally. I fully torqued each corner leaving the other corners little more than finger tight. I repeated this at all four corners before finally torqueing them down. The .0001 indicator never fluttered. I thought this was pretty impressive given other modern machines that I’ve seen where the headstock alignment could be changed with just torque differences. Not so here.
View attachment 386918 View attachment 386919
Your lathe was born in 1955 and rebuilt in 1962 - look to the left of the model number and serial number and you will see "rebuilt" stamped in the tag verticallyI have Carl's old machine as well, he did a wonderful job with the repair!
That's not my lathe. Just a photo I found on the internet. I had a 1020S that I sold a few years ago.Rusty,
is your's a 1020s for 1020f?
Thanks. I haven’t done a write-up of this machine. I have shown a few pictures of it but not a whole lot more. On a couple of occasions, I’ve mentioned that I’ve changed the spindle bearings on this machine. I’m sharing a few more details impart as I am curious if anyone else has found some of the issues I came across.beautiful restoration!! do you have a write up of the restoration anywhere online?
jeff
Notice
