Hello,
On my Robocut I have a problem that dimension of square is not the same in X and Y.
Difference is 0.02 mm and this is too much, also round hole is cut oval.
I make a test and measure 100mm long block on X and Y direction and machine shows max error of 3 microne.
So, positioning is OK, but why I get this difference when I cut the part?
Also I found out that position on Y direction is not OK, when I use measure cycle for centering on two edges
machine show me exact dimension, but after cuting the shape is dislocated for 0,02mm.
Have any idea what I can check?
Is it maybe some parameters?
Regards, Damijan
Regards, Damijan
