RoboDrill and not running M-codes
Schultz
Jul 6, 2021
I have three older Robodrills wit the 16i control that I have added additional M-codes and ladder logic to open/close a side door and work holding vices. Two of the three mills work and execute the M-code/custom ladder fine. The third is a sister to the other two (purchased at the same time) and none of the M-codes for opening and closing the door or work holding vices work. I've double check the wiring to the solenoid. Are there any parameters or keep relay parameters that turn on the custom ladder program? Any other ideas would be appreciated.
footpetaljones
Jun 21, 2018
Check K15.7, it turns the custom ladder on and off for Robodrills. Depending on who wrote the ladder, you might also need a data parameter turned on in order to call a subroutine for the M codes.
