William E. Matz
- May 22, 2022
Come across a 14" Rockwell / Delta (Rockwell Manufacturing Co. - Power Tool Division - Pittsburgh 8, Pennsylvania - US of A) Serial 124-5081. What I can gather is this machine was manufactured in 1959, but I am not certain. The head casting is very similar to a DP-225, how ever it is not, no numbers are apparent in the casting from what can be seen without disassembly. The column bracket is clearly marked DP-502, and it is attached to a 10.5" x 10". It has a Rockwell .5 HP dual voltage 1725 rpm motor which drives the quill through a 4 step pulley. Anyone familiar with this machine, where head casting numbers would be located along with machine literature would be appreciated.
Thank You
Thank You
