Roctech 1530 ATC - 5ftx10ft CNC Router (8KW HSD Spindle 24K RPM)
CNCWoodarts
Nov 23, 2022
Selling our lightly used CNC Router.
5ft x 10ft bed
3 Axis
24K RPM Italian HSD spindle - ISO 30 taper (Awesome spindle, quiet, powerful and has been very reliable)
Yaskawa Drives/Motors and Servos
Automatic Tool Setter
Syntech Controller
8 Tool ATC
Extended Z-Axis
Vacuum Table
Machine has about 750hours on it. Purchased new around 2018, it barely gets used. No known issues. Runs great. Excellent value for cutting things like panels and cabinet parts. Also does simultaneous 3 axis movements. Check out my instagram page for example of things cut on this machine. The spindle is great, cuts though hardwood with 3/4" end mills no problem. Rapids are 1000in/min. Its fast and pretty rigid. The syntech controller is simple and effective. Works well with Fusion360 CAM.
Located in Kailua Hawaii. Will ship anywhere. You must pay for shipping.
$25000 + Shipping firm
(Around 40K)
Pictures attached and Videos here:
CNCWoodarts
Nov 23, 2022
Also open to trades. Will consider trades for full metal machines, Robodrills or similar compact machines.
CNCWoodarts
Nov 23, 2022
Bump. Still available. Needs a new home. Can provide remote setup help and help getting started. Will possibly to your location at the time of delivery in order to help you get started if you are new to CNC machining.
Comatose
Feb 25, 2005
Akron, OH
By the time somebody got it shipped from hawaii, the cost is pretty close to a new one on the mainland. Aren't there any sign shops or cabinetmakers more local to you that might want it?
CNCWoodarts
Nov 23, 2022
Not true. We just bought a 4 axis machine from the same company to replace this:
1) Shipping is $9000USD from China to Hawaii, not even to mainland
2) Import tarrifs were $15000!!
If a brand new 3 axis machine was $25K (its more than this for sure) loaded with all the options, you would still pay at least $45K to your door even on mainland. So for this, we can arrange shipping for around 5K or less and no import fees. Thus It could be as low as $30K to your door which is $15,000USD cheaper than buying a new one.
