I can not see what it is doing so I can not diagnose what is wrong because I don't know what it is suppose to be doing. I don't know if that makes any sense to anybody but that's how I see it. I would be grateful for any tips on how and what to check.
"Funny you should mention" "can't
see it".
That was sooo freakin' FRUSTRATING . .having only a VOM, then VTVM, I had acquired my SECOND Oscilloscope by age nine and two more by age 13!
More since as I keep upgrading, but I only had to rebuild four of them from junk.
Back when I still had more brains than money.
(Funny how that reverses in later years, ain't it?)
But 'scopes are cheap as dirt nowadays!
Y'see.. nearly everything that happens in a 10EE falls within the "audio passband." So IF one had a probe that could SAFELY connect to an iPhone or laptop PC?
Most already have display software to analyse that "audio" spectrum.
There are in fact, such plug-in gadgets made. I'm no fan of their safety, however.
A 10EE with "Contactor Reversing" can draw a spike around five TIMES the service Voltage. 1500 Volts? And a bit.
Typical meters are also suspect. Check the ratings. And where made.
I prefer an inexpensive quad-trace Rigol 'scope, but the older one is a Fluke that cost the very EARTH when new, Had GREAT test leads.. so.. nothing for it but to buy a set of high-Voltage "multiplier" leads and no-gettee-fingers-here probes for the Rigol. Which cost MORE than the Rigol scope had cost. US-made leads. Vs Chinese made scope.
Meter, scope, or just "wet meat" (yerself!), HIGH VOLTAGE is the killer.
And that is NOT just a figure of speech!
A 10EE is chock full of "lethal" Voltages.
Rectified or rotating, Dee Cee is deadlier than AC. No reversal = no "OFF point that "might" THROW a body off. DC is called "stick and fry" or as our former moderator put it: being "rectumfried".
"Job One" is safe operating practices.
Habit of close-on 70 year for those among us as started with hollow-state and Tee Vee with high voltage Cathode Ray Tubes.
Potentially deadly-dangerous as to bad habits for those who came in with low shock hazard low Voltage transistor audio gear and silly-puters.
PM is not the only place to learn about such things. Nor the best. Internet is chock full of sources.
US Navy training courses and their publications are about as clear and well-written as anybody has ever published anywhere. Kinda inconvenient to call a tow-truck for a submarine 600 feet down? Every man has to know his speciality. And then some.
Those can be found cheap or even free without having to sign up and wear a uniform..
US taxpayer funds a thing? US public is entitled to the benefit of it.
So long as it is not classified for security reasons.
NASA publishes as well. And "not-only".
Never too old to learn new things. Maturity even makes it faster and less stressful than it might have been in impatient and less confident/relaxed youth.
Learning as a hobby in one's "golden years" even makes up for some of the "fun" things no longer as easy to do.
If-even a perpetually 23 year-old wife of 31 years would
allow those!
