After extensive researching here and on the web I decided to just post up a question. We have several machines that we are trying to get under power from single-phase source. 100A 250V (two ~124V legs) single phase source supply both locations.
Location 1
• Bridgeport EZPath SD Lathe
• Bridgeport EZTrak mill
• Additional machine down the road, surface grinder, etc. maybe two running at the same time if all of them is not an option.
Have 20HP idler motor for rotary phase converter
Location 1
• Fanuc Robodrill alpha T21iD
• Additional machine down the road, similar size or a little larger
Have 25HP idler motor for rotary phase converter
The questions are in implementation. As we get ready to power these up my concerns are in the balance voltage, stability and quality of the power for the CNC machines and the overall high voltage already which is already pushing the upper limits and the generated leg will likely go way over the top. My understanding is that at least the EZPath can be fussy with the high voltage if not all of the machines.
Possible solutions,
1. Just balance it out and hope for the best using capacitors (what load do we target for best results as the machines cycle?)
2. Use a transformer on the third leg. I have read several recent posts by JST that this is a better way to go. Transformer on the third leg only or get a triple and do all three legs? Is there a thread out there already detailing the transformer third leg option?
3. I have found a couple of VFD units that are probably high enough to work 22KW-30KW. Costs a bit more but if it saves problems down the road would be worth it. If we choose this option is there any advantage to powering the idler with the VFD (soft start that motor) then pull the machine load center off the idler motor?
Thanks in advance for any help you can offer.
Dave
Location 1
Location 1
Possible solutions,
Dave
