I want to build a 600V rotary phase converter and I'm struggling with the choice for the run capacitor. Are they mandatory? If yes, any tips on how to choose the capacitor for that third leg? Do the voltage need to be around 575, or can I settle for lower? Do I need to bother with the third leg phasing?
To keep it short, I've got:
What I need:
from the following video:
Disclaimer: I've tried with a vfd between the transformer and the outlet, it burnt instantly. I'm not planning on settling for a 3k$ 575V VFD when I need to spend about 200$ for a RPC.
If you also have a RPC, I'd like to know how the abnormal phasing of the third leg is affecting the motor.
- 1xbridgeport pancake 3ph 575V 3hp motor
- 1x5hp 3ph delta 575V 1155rpm idler-to-become motor (I've also got a wye one, only difference is that it's 3600RPM and 50 pound lighter, in case it's what I truly need)
- 1x10kva 3ph 208-575 transformer (to 240V 1ph to 640V 1ph for at most 6.6KVA)
- monophase 240V outlet
- 1/6 hp 1ph 1750 rpm motor to spin the big one
What I need:
- run capacitor bank (exact capacitance unknown, that what I'm here for)
- Misc. electrical stuff (mag switch, box, button, etc)
- 10 KVA 240-208 transformer (running a 575V motor at 660V seem dangerous)
