jim rozen
- Feb 26, 2004
- peekskill, NY
3 hp load motor, with a 5 hp idler, will probably need tuning via capacitors to get it to peform well. In my case the idler is 5 hp, and the largest load motor is 1 hp. This is why I can get away with zero capacitors in the system. All you need to do is look at digikey to see 600 working voltage capacitors. They're not that expensive.
