Jim Moser
- Sep 5, 2004
- Santa Cruz Ca.
I have a Graziano Sag 12 two speed motor lathe 1725 and 860 rpm windings. Never could figure out the contactor wiring for the low speed and the high speed started chattering so I opted to bypass all the old mag starters and try a vfd direct to the motor. Got a Vevor h100 7.5 hp import vfd. It starts the motor fine on both sets of windings but on the high speed when I engauge the electric clutches it shuts down with an over current error code. The low speed winding behaves better as I can use the first 3 speed clutches but 4th speed shuts it down with OC error code. Is there some kind of OC buffer parameter I can look for? There is hundreds of parameters in these things. Maximum motor amps is 16 and the vfd is rated for 33 amps. Seems like the instantaneous engaugement spikes the unit and shuts it down. Plus the thing has a high pitch whine I don't. Like. I have 4 other vfd's that are quiet and work great. I thought I oversized this enough but it does seem small for a 7.5 kw, all my other ones are 1 to 3 hp.
Any thoughts
Thanks. Jim
Any thoughts
Thanks. Jim
