Walther1522
- Oct 16, 2023
Hello all,
Quick question on the south bend lathe 9a vs 9b.
Recently I was gifted a 9b and am in process of cleaning, repairing, modifying and restoring (if i can say that) this 9b into a 9a.
I have acquired a QCGB and new lead screw for this 3 1/2’ bed to accommodate the QCGB.
From what I understand this is the only modification needed apart from drilling the extra counter sunk screw hole in the bed to put the QCGB onto a 9b.
I had two questions. Concerning this mod.
The first, what are the two gears that are standard at the gear train on the head stock end when in the 9a configuration?
I know that the 9b has several configurations but the 9a only has two that consist of swapping only the 20t and 40t gear. From my understanding the QCGB eliminates having the need for change gears in the gear train.
Secondly, I have a gear banjo that does not have a guard plate like the 9a does. Ill post pictures of what I mean.
Is this a problem or will it function fine?
Thank you all for any help
