Schaffner milling machine.
The machine was built in Switzerland in 1958, and as most swiss made products, is very well built. The condition is very good (The machine wears its genuine paint, no marks on the table).
The table measurements are 700 x 200mm (27,5 x 7,8 inches), with the following travels x : 400mm(15,75 inches), y : 150mm (5,90 inches), z : 250mm (9,85 inches).
The sliding ram supporting the vertical head gives the machine even more y capability since you can set it to have the best crosslide position possible when working on different sizes of parts.
Inclinable vertical head and horizontal spindle. An interesting feature is that you can use the horizontal spindle without removing the vertical head (Even DECKELS don't have the same).
most of the times, you even won't have to push the ram backward. therefore, you don't need to re-set up the vertical head each time you want to use the horizontal spindle.
The spindle noses are SA 40 (ISO 40), This is rather unusual for a machine of this size, on wich you would be more likely to find MT3 or SA/ISO30 tooling, but it is very convenient since ISO 40 tooling is extremely common (thus easy to find and affordable) in Europe.
The spindle speeds are infinitely variable from 40 to 2200 rpm (expanding & contracting pulleys drive). This driving system makes it a VERY silent and quiet machine (A point that sould'nt be neglected by the home-shop machinist...)
The x axis offers infinitely variable power feeds from 40 to 126 mm/min, with adjustable (and precise) stops.
The main motor is 3Ph 2,5HP, and there's a built-in cooling system.
This forum seems to be very america-oriented, but if there's someone interested around, this machine is currently for sale, and the asked price is 1800 Euros.
I may sell some equipment with the machine, including a precision milling vice (pretty pricey item), end-mill holder and collets, drilling chuck, and a Kaiser boring-facing head (very pricey item).
The complete package would sell for 2300 Euros.
The machine
The two ISO 40 spindles
I said good condition...
The speed dials
You want some Sean ?
All in all, the machine is may be not as universal as a DECKEL would'be, but is very user-friendly and WAY cheaper (Not to mention that most of us don't need a tilting and swivelling table everyday...).
If it sounds interesting to you, E-mail me.
The machine
The speed dials
